Meraki dashboard showing wrong IP addresses - how to force refresh?
Meraki Dashboard Clients display seems pretty unreliable. When I view it I see 10% of the clients with duplicate IP addresses. When when I use an IP scan tool or manually investigate, I find that one of the pair of dups actually has another IP address that isn't shown in the Client dashboard as being assigned at all. Is there a way to force a rescan or refresh of the client listing to ensure it is accurate? It is basically useless as is, since I can't trust the data.
If by hotspot you mean a WiFi access point, a few are WiFi but most are wired. The device types are varied. Linux based audio streamers, Roku video streamers, Amazon Echo devices, Win 10 PC, iPads, other home automation devices, etc.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_68f59ad3bb668f","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_68f59ad3bb668f_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_68f59ad3bb668f_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_68f59ad3bb668f_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_68f59acd180c44","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
