Meraki certificate expired
ChrisP-NZ
Looks like the *.meraki.com certificate has expired. Hence my clients getting Curl Error 60 when trying to check in.
9 Replies 9
Have you opened a support case?
ChrisP-NZ
Yes I have. I figured it might be useful to put some info up here too.
AnitaF
I opened a case yesterday for this issue.  I'm also seeing the curl error 60 and "the certificate expired 5 days ago" if I go to the URL.  Support doesn't seem to be on the same page.  They're telling me it's my agent version.
ccoho
Also have a support ticket opened regarding this.  It looks like they did renew their cert (check the cert on the meraki dashboard https://n342.meraki.com/), but whatever system is hosting cf.meraki.com hasn't been updated with the new cert... this should be a very easy fix to apply the new cert - and considering its unusable right now I would think would be a priority, but I put the case in yesterday morning and still nothing.
ekramer
I had a cached cert.  On refreshing my Meraki dashboard it pulled down the updated cert with dates into 2024.
ccoho
This is correct for the dashboard, but they have not updated the systems hosting cf.meraki.com with the new cert... go to https://cf.meraki.com/cf/config, the cert is still the old one (as of now)
ccoho
support finally responded that they are aware of the issue
ChrisP-NZ
Looks like this is now resolved. The cf.meraki.com certificate now has an expiry of 24 April 2024.
AnitaF
My environment is back to normal!  Hope everyone else sees the same!
