Meraki System Manager - Unbind Google EMM
Wardy
Good afternoon,
We want to unbind our google domain (EMM) from Meraki and manage everything via the Google Admin centre. We're having trouble finding any documents to do this, has anyone got any ideas or have done this?
Regards
Paul
MRCUR
You will need to be an org admin to do this.
Go to Organization - MDM. There is an "Unenroll" button in the Android for Work section. After you do this, you should be able to set up Google as the EMM provider in the G Suite Admin Console.
MRCUR | CMNO #12
MarkHolloway
Just browsing
What if we removed the System Manager network before doing so? We inadvertently thought removing the System Manager network would automatically unbind, and it did not.
MRCUR
Your best bet is to open a case with Support and see if they can complete the unenrollment process for you since you've deleted the network.
MRCUR | CMNO #12
Wardy
Hi
This worked for us courtesy of Meraki Suppot
Navigate to "Device Administrators" within the Settings application on each device and disable the Meraki SM app as a Device Administrator. Next, you will want to uninstall the Meraki SM app from each client. At this point, the devices should no longer be bound to Systems Manager. Additionally, if you would also like to remove the clients from your Dashboard, you can then also navigate to Systems Manager > Clients and select the devices and then use the "Delete" option.
When we then logged into Google Admin dashboard there was an Unbind option in the EMM options.
Good luck
Paul
