Hi @Shane_Martin,
Can you verify you haven't reached your licence limit? That can keep them from showing up if you are using the agent.
Found under Organization > License info
Found this helpful? Give me some Kudos! (click on the little up-arrow below) and If my reply solved your issue, please mark it as a solution 🙂
