Meraki Profiles not showing
XXDXX
I've created a Profile (Teachers) in System Manager > Manage > Settings
I've place a Teacher Tag on the iPads.
The Teacher Profile is not pushing out and I can't see the Teacher Profile even after I clicked on the Refresh profiles list.
Did I missed something?  Thank you in advance.
28 Replies 28
MikeMandalorian
Do you have the Devices in hand or are they out in the field,,  if they are out in the field the Ipads will need to be on WIFI already and Unlocked in order for the settings to be pushed out. When i push out settings remotely i also ask the Enduser to open the SM meraki app to verify 4 green check marks
kYutobi
You cannot push profiles to iPads that are unsupervised. I see that in your menu it says " Supervised:NO ". You can however still push apps.
Enthusiast
MikeMandalorian
@kYutobi i have Profiles pushed out to Managed only devices
kYutobi
@MikeMandalorianI have devices that aren't supervised and I cannot push settings to them. I had asked and it is said that it can only be done on supervised devices unless something changed.
Enthusiast
MikeMandalorian
Ignore the App missing  its not profile based
kYutobi
@MikeMandalorianHey Mike question for you. Do you have a tag that is associated with settings? It will look like it's clear if nothing is set. This is what I get when I try to push settings to it.
Enthusiast
MikeMandalorian
Yes i do have a  Tag assigned to that device
kYutobi
Right @MikeMandalorian I get that but do you have settings tied to that tag? For example I just removed tag that had settings to it, did an update, and its cleared.
Enthusiast
MikeMandalorian
yes , for Managed only IOS , we use the generic IOS devices tag
kYutobi
So if you were to make another random settings and add IOS tag to it will it apply? This is the part where if you add settings it won't push.
Enthusiast
MikeMandalorian
Stand by i will do this on a Roll off IPAD i have that is not in DEP,,  to be clear i cant give it the IOS device tag as it will interfere with other setting i have out there , but i will Copy the Managed Settings profile
kYutobi
No problem. @MikeMandalorian Just create a fakeipad settings lol.
Enthusiast
MikeMandalorian
All good on my end , pushed out the settings , even forced out App downloads like the SM meraki mdm app
kYutobi
Only difference I can ask is if you have SM Enterprise? I've been on legacy since before Meraki became Cisco. I just thought that if an iPad isn't in DEP or Supervised you can't push profile settings to them.
Enthusiast
MikeMandalorian
@XXDXX  @kYutobi   I even added Wifi  on the Profile Configuration  and  it Updated on the Ipad
MikeMandalorian
I apologize , i should have stated that we have the Full Meraki MDM
kYutobi
Well that would kinda explain it since the Full MDM does have more features. @XXDXX if we both have the regular MDM it might be we are limited to this function. @MikeMandalorian Thank you for all the extra time you spent with me on this 😃
Enthusiast
MikeMandalorian
Anytime Sir, that is why this Community is here !
vassallon
@kYutobi Seeing that the iPad is not DEP-enrolled nor Supervised that also will limit the amount of things you can push to iPads.
Here is some documentation from Apple that helps you understand what is dependant on the device being supervised.
https://help.apple.com/deployment/mdm/#/mdm54960f92a
BlakeRichardson
@XXDXX  First confirm the device you are trying to install the profile on is listed in the targeted list for those settings.
Next When you try and commad the device to update its profiles what messages do you get in the Activity log.
XXDXX
I now got the profiles showing, but as you said, those iPads are not Supervised and it does limit the things I want to push through.
However, I've tried to get those iPads supervised but failed.
kYutobi
It has happened to me before where if I don't purchase the iPads from Apple I can't add them to DEP. Other option would be Apple Configurator and have them supervised through there worked for me.
Enthusiast
XXDXX
Thanks for your reply.  No wonder I keep getting errors when I tried to add them in Apple School Manager, and of course the error log they asked you to check doesn't say what error it was.
vassallon
@XXDXX
Here is what Apple has to say about getting the devices enrolled.
If you’ve acquired devices outside of Apple or participating Apple Authorized Resellers or carriers, they can
also be added to DEP using Apple Configurator. When you set up a device that has been manually enrolled,
it behaves like any other enrolled device, with mandatory supervision and MDM enrollment. However, the
user has a 30-day provisional period to remove the device from enrollment, supervision, and MDM.
Learn more about how to manually enroll you devices.
I even left the typo that is in the Apple DEP document.
https://www.apple.com/business/site/docs/DEP_Guide.pdf
XXDXX
Thanks for the info, I will read in to that.
XXDXX
Thanks, I'm going to see how to get it supervised and try
MikeMandalorian
If you have the Free version   I would suggest to upgrade , then from there you would need to Enroll in Apple DEP and VPP . or Apple Configurator   once all that is done  if all your IOS devices are from the same vendor , add them as a authorized DEP vendor  and they can push them to DEP from there you sync with Meraki
here is the Meraki Documentation to help you get a larger scale on it
https://documentation.meraki.com/SM/Profiles_and_Settings/iOS_Supervision
XXDXX
But the WiFi profile got pushed, that's why I don't understand.  But the Wi-Fi profile is set to All devices where as the Teacher profile is tagged.
