MDM - Win 10 Send Client Notification
MrSmith
did someone use the client Notification function in Meraki MDM with Win 10?
How can i force the Notitication PopUp to be displayed in the foreground ?
Thank you
5 Replies 5
felix_fx2
Hi Smith,
Yea i use that every now & then to send warning to pesky users. you'll need to at least have SM agent installed.
It's a cscript based notification on the foreground, not the notification pane from the right.
MrSmith
Hi Felix,
thank you for your Feedback.
The agent is installed, but the only thing i see if i send the notification is this blinking icon:
I have to click on the icon to see the message. What im looking for is, that the message should be displayed in the middle of the screen as soon as i send it out.
felix_fx2
Hi Smith,
Which version of the sm agent your using?
I assume your endpoints are using windows 10 enterprise 1703 also.
MrSmith
Hi Felix,
i am using SM 1.0.95
felix_fx2
Strange, i am at the same version.. but i get the cscript prompt on screen... something else within your system settings might be the culprit..
You could try verify this by enrolling a system that is vanilla Win 10 1709.. so you can start isolating the cause
