Kiosk Mode on Samsung XCover 4s mit Android 9 not Working
MichelRueger
Hi All,
Does somebody already using Kiosk Mode in Android 9 Version? We have a Profile pushing the Samsung 4s in Kiosk Mode with 4 different Apps but none is Showed! If i exit the Kiosk Mode all apps are installed and working perfekt. If I go back in Kiosk Mode Kiosk Mode is running but there are no Apps Showed. Even if I completely Factory reset the Phone and deploy it again. The Phone are in device Owner Mode. We have a lot of Samsung 4 with Android 7 and there it is working perfekt!
Thanks for any Help on this.
Noah_Salzman
Meraki Alumni (Retired)
Hello Michel, please log this as a support case and copy the case number here.
Freundliche Grüße
Noah Salzman
Product Manager for Meraki SM
MichelRueger
Hi Noa
Just did it 🙂
Cisco Meraki Case 0435191
Thanks Michel
MichelRueger
Hi Noah,
We just found out that the Problem only happen if you rollout a Phone witch is already in the Device List. (Has ben rollout before) If you delete the device in the Dashboard and you factory Reset the Phone it works perfect. I updated the Case with pictures and all the necessary comments.
Regards Michel
