i have brand new 115 ipads in Meraki they are split up in to 4 settings group , all of the setting are the same ( but split up for different counties)
i turn on iPad> select Language>United States>connect to WiFi>informs me about config profile > installs config profile > Then here is where my issue starts ,, we use a 4 digit pass-code , when i select pass-code options for 4 digit , it does not always bring up pass-code option . i have to hit the back button then it will let me select 4 digit , i enter in the 4 digit code twice and then boom the Ipad restarts , and does not remember the pass-code and goes to the home screen with No pass-code on the device ,, because of our settings i have it set for end user not to be able to change the pass-code so i have to Erase the device and start over again, it happens on 6 out every 10 Ipads , to me it doesn't seem to be a meraki settings issue because it doesn't do it on every single one.
(everything is supervised)
