INFO: radius.meraki.com certificate renewal for Sentry WiFi
PaulF
Hello all.
As many of you may have received an email recently talking about the radius.meraki.com certificate renewal, I wanted to give a little more context, show a script you can use to do a survey of all of your devices and highlight devices which DON'T have the updated cert, and the implications of no action
Firstly, you may have received an email, or seen the banners in dashboard:
This takes you to this page: https://documentation.meraki.com/SM/Other_Topics/Meraki_Authentication_Server_Certificate_Rotation_-...
You've received this because you may be using Sentry: This is when you use certificates to authenticate onto an SSID on Meraki MR, the certificate being automatically generated for Systems Manager devices
So, how do you determine which devices need action?
I wrote a script, available here:
 https://github.com/meraki/automation-scripts/tree/master/RadiusCertSurvey
There's two files:
RadiusCertSurvey.py
RadiuscertSurveyResults.csv
If you have already done so, you'll need to install the Meraki Python Library: Information here: https://pypi.org/project/meraki/
Once you've done that, you can run the script with:
python3 RadiusCertSurvey.py -k <yourapikey> -n <YourMerakiNetworkID>
(venv) RadiusCertSurvey % python3 RadiusCertSurvey.py -k REDACTED -n REDACTED
Meraki Library version:
1.27.0
Please enter the expected radius.meraki.com expiration date
in the format of YYYY-MM-DD : 2023-11-29
(there's a -v parameter you can use for Verbose mode that gives you details of every device)
When this runs, it will ask you for the expected radius.meraki.com certificate expiration date. As this is 2023-11-30, enter the day before, as shown above
This will generate a file that has, as an example, the following in:
🐻 iMac 27 serial : C02DDDDDDD
URL to device : https://n562.meraki.com/SM-Demo-systems-/n/REDACTED/manage/pcc/list#pn=68111111111
2020-08-13 2022-08-01 2023-02-08
bad news, no updated cert
🐻 Windows10VM serial : VMware-56 4d 63 49
URL to device : https://n562.meraki.com/SM-Demo-systems-/n/REDACTED/manage/pcc/list#pn=68222222222
2022-08-01
🐻 Cisco 840 serial : tcl2449005y
URL to device : https://n562.meraki.com/SM-Demo-systems-/n/REDACTED/manage/pcc/list#pn=68333333333
2022-08-01
🐻 Windows 10 Ent serial : VMware-56 4d e6 b4
URL to device : https://n562.meraki.com/SM-Demo-systems-/n/REDACTED/manage/pcc/list#pn=68444444444
You'll be able to open the links directly to the device in dashboard, allowing you to investigate
0 REPLIES 0
