How to install Cisco Umbrella Roaming Client using Cisco Meraki System Manager
ManiSai
Kindly help me to install Cisco Umbrella Roaming Client using Cisco Meraki System Manager,
Please provide me exact details or documents specific  to Cisco Umbrella Roaming Client using Cisco Meraki System Manager
Note-Not the general documents of Meraki please, as the does not provide the installation argument or details about these organization ID etc...
As it get installed when i just upload the MSI file to Meraki Sysyem Manager APPS, but Organization details are not fetched.
Please provide me the exact installation argument or help me to install Cisco Umbrella Roaming Client with OrgInfo.json(Full Organization details).
Cisco Meraki System Manager :
Cisco Umbrella Roaming Client :
6 REPLIES 6
CptnCrnch
we are not looking for other Devices currently. Looking only for Windows PCs.
More over API integration is also not the solution we are looking at.
We are planing to deploy Cisco Umbrella Roaming Client using Cisco Meraki System Manager - Apps feature,along with this organization info also to be fetched. This is mostly for our own understanding.
afasquel
Hi ManiSai
Have you found a solution yet? I'm in the same situation as you!
Kind regards
Alex
T1
If you Google for "Cisco Umbrella Roaming Client unattended installation", the desired result is on the front page.
https://docs.umbrella.com/deployment-umbrella/docs/appendix-g-command-line-and-customization-for-ins...
Hey I ended up finding a solution for anyone looking at this thread
Meraki's documentation shows the following:
msiexec /i Setup.msi /qn ORG_ID=222222 ORG_FINGERPRINT=1234567890abcdef USER_ID=111111
If you are pushing it out from Meraki, once you have the Setup.msi file uploaded the installation arguments are as follows:
The documentation is very misleading as you have to omit the filename for it to work
