Feature Request: Add iOS13 HomeScreen Shortcuts to Home Screen Layout
Tom-B
Probably more of an Apple Request rather than Meraki but I would love the option to add shortcuts to the homescreen layout.
i.e.
I create a shared shortcut for a specific task (i.e. Open the Systems Manager application ), place on the homescreen with a different icon and put on multiple iPads via an iPad backup.
Meraki then allows me to position this shortcut on the homescreen as it does with apps, webclips, etc.
I used to use webclips pointing to urlschemes to do a similar job, but they dont work on iPadOS13 - seems to be a bug when you use more than one according to discussion here:
javascript - Detecting when iOS Webclip is launched whilst working around an iOS 13 bug - Stack Over...
1 REPLY 1
BlakeRichardson
I find that I am only able to add a singe webclip now and I have to add it directly to the profile rather than using the "home screen layout" payload.
www.btr.net.nz
