Exchange Active Sync with S/MIME not working
RaPo
Hello everyone,
I have created an active sync profile for iOS devices (iOS 11.4). I now want to enable certificate based E-Mail signing with a .pfx certificate from GlobalSign. Therefore I enabled
- Use SSL
- Use Client Certificate Authentication
- Enable S/MIME Message Signing
The certificate for the user was added using Owners -> Import -> Import certs and is properly shown at the owner and is transferred to the device.
E-Mails can be received but when I want to send a mail I receive the popup "signing not possible … no signing identity found". If I create the mail account manually the cert is detected properly and everything is working.
I also converted the .pfx into a .p12 cert but same problem
Have I missed anything?
Kind regards
RaPo
4 REPLIES 4
Are you using Outlook for iOS, or some other email client?  It not, I would try using the native Microsoft client.
I have found the mobile version of Outlook has much better integration with Exchange - but I have never tested S/MIME with it.
RaPo
Hello PhilipDAth,
no, we´re using the native iOS Mail App. Outlook App on iOS does not support SMIME.
When creating the profile manually with the usage of the Meraki pushed user certificate it works. But with the pushed Exchange active sync profile not.
Additionally I tested first creating the Active Sync E-Mail account manually with SMIME and then pushing the profile. In this scenario everything is working fine, too. But as soon as I remove the manually created profile I get the same error with not finding a valid certificate again.
Ralf
uptimejeff
You may need to manually select the certificate.
http://www.entrust.net/knowledge-base/technote.cfm?tn=70598
RaPo
Hi uptimejeff,
thanks for the reply. Manual Import of certificates is no Option as we plan a mass roll-out of 3500 certificates within our POC.
End of last week I was informed by Cisco Meraki that they changes something and I have to create a new profile. There are now new checkboxes available we did not have before.
Now everything is working fine.
Thanks all for your help
