DEP/MacOS: Setting up firmware password remotely
FlorianHein
 Hi community,
I'm trying to find a way to set a firmware password remotely for supervisioned MacBooks that got the agent and profile installed via DEP.
I tried using the Terminal function in Meraki SM and the sudo firmwarepasswd -setpasswd command on a brand new Macbook, without any success. There was no firmware password set before.
Background of this request: We want to order Macbooks to our coworkers private adress directly, without having to setting those devices up in our office beforehand.
Any directions/ideas are greatly appreciated.
Best Regards
Florian
1 Reply 1
BlakeRichardson
I don't know if this is possible using Systems Manager, usually it required setting up a payload in a profile. SM doesn't seem to have that option.
I would contact support and ask them if its possible as I have not found any Meraki documentation explaining the process but have found plenty for other MDM vendors.
