Content Filtering Remote Users
cplatt
What do you all do for content filtering on Remote iPads? I was going to set up Per App VPN with Chrome until I found out per app only supports Cisco AnyConnect, which cannot be used with MX Firewalls. So whats the best solution to limit their content (adult sites, etc) while these users are remote.
jared_f
@cplatt Assuming the devices are supervised you could push out the content filter configuration profile and set it to "Auto Filter"
(Systems Manager > Settings > Create New Profile > Restrictions > iOS Supervised)
6 Replies 6
jared_f
cplatt
Does that work with any browser or just Safari?
jared_f
@cplatt I believe so, do you have a test iPad to scope it to? If not, let me know and I will do it.
cplatt
NVM found the answer to that question it works on all thanks for the help!
cplatt
cplatt
Confirmed it works in Chrome.
