Can AMP Be Installed Via CLI?
Ed-Dolle
Just browsing
I am adding AMP into the Apps section of Meraki and would like to add arguments to the install file and add credentials. Is this possible?
5 Replies 5
I'm not completely clear on what you need.
Are you need to add command line arguments?
Or are you saying you have a bunch of files (such as an installer and an answer file) and you need them all deployed to the machine and then have the installer run?
Ed-Dolle
Just browsing
Yes, command line arguments.
When you add a custom Windows app for deployment it lets you specify the command line arguments down the bottom.
Ed-Dolle
Just browsing
Correct. I can add the arguments there. But … what arguments do I type in?
