Bulk Uninstall - MDM on OSX and Windows
felix_fx2
Hi Folks,
Got a good question, in need of a very good answer.
I currently have the need to remove CCleaner due to the malware payload of recent my bosses have decided to blacklist it all together.
I could click uninstall manually but sadly my fingers or mouse will likely fall apart of suffer a crap clicking 3K+ times & now i am looking for a easier way to uninstall all version of it in a more automatic method (this will prove very useful for other software in future).
btw, i can't see ccleaner in my windows software inventory list (but i can see everything else, likely a bug and a case already logged).
For Windows go to Systems Manager/Command Line.  Select all Windows machines.
Now the bit I am not sure of.  Try this:
C:\Program Files\CCleaner\uninst.exe /S
Failing that, try using "msiexec /u" and put in whatever package name CCleaner uses.
5 REPLIES 5
This might also do it (not tested by me):
MsiExec.exe /uninstall{1827CDDB-1B8A-4A35-B365-60C1C8F79D0C}
That was good lead. i used the below,, thou it timed out on majority of systems.
"C:\Program Files\CCleaner\uninst.exe" /S
For those who want to do it via powershell (intune should have this as beta feature)
# Checking Presence of CCleaner
Get-ItemProperty -Path HKLM:\Software\Microsoft\Windows\CurrentVersion\Uninstall\* |
Where-Object DisplayName -match CCleaner
# Stopping CCleaner64 & CCleaner running process, this will have errors if it is not running. keep calm and carry on
stop-process -name CCleaner64 -force
stop-process -name CCleaner -force
# Starting uninstaller
if (Get-ItemProperty -Path HKLM:\Software\Microsoft\Windows\CurrentVersion\Uninstall\* |
    Where-Object DisplayName -match CCleaner -OutVariable Results) {
    & "$($Results.InstallLocation)\uninst.exe" /S
# Removing install folder, this should prevent even if uninstall failed
Remove-Item "C:\Program Files\CCleaner" -Force
It may have timed out if the uninstall took longer than 45s - but still have completed the uninstall.
in which i have no visibility for (Completed/Failed/Timeout), one of the caveats for Meraki MDM.
I do have a case logged since ccleaner is shown in "program & features" but not the returned in the CLI which was used to capture.
But this section is really cool..
