Hi Guys,
Just testing out Meraki SM for my organisation. We've purchased two brand new Android Enterprise devices and successfully registered them in 'Device Owner' mode.
I've got all green ticks on the devices on 'Device Administration Enabled', 'SM is the device owner', 'AFW account enabled', 'Location Services Enabled'. So all looks good. I can see them OK in the Meraki dashboard and can see that policies have applied correctly.
However, when I try to deploy an application to the device, nothing happens. I select 'auto install', but it doesn't auto install. In the logs in the dashboard, it says 'Install App xxx', and 'success' - but nothing is actually happening. I've gone in to 'managed apps' in the SM app, and can see the app there, but when I manually click 'install', it just says 'Downloading' (temporary grey message at the bottom of the screen', and then does nothing.
Also, every so often I get 'Unfortunately, Meraki SM has stopped'.
Any ideas? I had high hopes for Meraki SM...
Device is the Acer Iconia One 7, B1-790 (Android 6.0).
Thanks,
Brett
