Android Box Recommendation
Hoggle
Just browsing
Hi All,
We are trying to find an Android Box with 9.0 "Pie" installed, that allows us to add it to the MDM and install a work profile.  The closest we have gotten so far is with a Minix NEO U22-XJ, it enrolled with MDM, however it does not support encryption on the current firmware and so we are not able to install a work profile.
I was wondering if anyone had an recommendations on what to try next.
Thanks!
1 Reply 1
I don't know the answer.
Samsung's usually work well.  Anything in that range that suits you?
