We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
We have a meraki MX64 that pipes the syslog to a collector where we filter the url data to see where users are going.
My question is, if we add AD integration to the MX, will the syslog show the username as well as the ip address?
TIA
Solved! Go to solution.
I don't know but the syslog file format page does not suggest that it would.
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/Syslog_Server_Over...
Ok, thank you.
I guess we will have to look at another solution.
