Episode 118: What’s New With the Meraki Learning Hub?
JeremyHolland
Meraki Alumni (Retired)
Want to advance your IT career? Look no further than the Meraki Learning Hub, where you can access courses and certifications to help you get the most out of your Meraki products and services while boosting your IT cred. Take a listen and hear from Philip Coburn, Senior Technical Trainer at Cisco Meraki, as he takes us through recent exciting updates to the Meraki Learning Hub.
Host
Tanner Yehlik—Technical Marketing Engineer, Cisco Meraki
Guest
Philip Coburn—Senior Technical Trainer, Cisco Meraki
Learn More
cs.co/learn
learning.meraki.net
1 Comment
AURELIOAC
Sinceramente el área de aprendizaje de Meraki, puede mejorar. Es sencillo, una persona motivada, quiere aprender, lo difícil es obtener una recompensa, un logro, acreditación de tu avance. ¿Crees importante que tu esfuerzo tenga un mínimo reconocimiento?
