Designed and tested SD-WAN to replace some L2 fiber connections.
1) MX84 as one arm concentrator at data center.
1) MX84 as standard Branch router
Integrated Meraki MX routing with HP core switch L3 routing in DC.
configured firewall rules at Branch to customize IP security.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
