port forwarding in Meraki go Firewall not working
markfit1
Hi All,
so ive put in a new Meraki GO FW and all works great however i now need to have my external phone supplier access there system from inside the FW on the LAN so in port forwarding i setup the rule for TCP on Port 7088 (the one they need) and there specific external IP (although also tried open from any IP) and still cant get into the system behind the FW and i thought this would be simple as the Meraki GO is very basic but has now wrecked my head and wondered am i missing somthign very simple here ?
any advice be appreciated
thanks
Mark
8 Replies 8
Xydocq
hello @markfit1
I've many forwarding rules and they work perfectly fine.
When you set up the rule, does it look like that?
I find it useful to select the Network the device is on first, before adding a forwarding rule. Not sure if that's truly required, it's just how I do it.
I add the Allowed Public IPS after creating the rule.
The Device you want to forward the port to needs to have a static local IP.
hope this helps
markfit1
Hi Xydocq,
thanks for your reply and ive done it the exact same way as i dont see any other way to do it .. then externally im trying the Public IP:7088 and nothing
regards
Mark
Xydocq
ok.
how do you test if the Port gets forwarded?
on Windows use Windows Powershell the command is test-netconnection ip-address -port 7088
Looks like you can use the local IP of the GX to verify if a port is open or not.
Next thing to check: The software runs on a pc? If yes, does this pc have a firewall installed that will block incoming traffic?
I had to set rules on my windows machines to accept traffic from a different vlan. Took me a while to figure out why I was able to ping the printer on the other vlan but not the pc.
hope this helps
markfit1
Hi Xydocq,
yes this will only work internally but does pass for port 7088 and port 5003, this is a internal phone switch so no PC but i can easily access this via a browser in the internal network. if i use the same method using the external public IP it fails i dont get any response,
thanks for your help
kind regards
Mark
Xydocq
Can you name the Phone provider, please?
markfit1
its a supplier here but this is the system .. however it did work fine (externally) before i put in the Maraki GO 😞
Xydocq
This is strange behaviour.
I added a new rule to access the webGUI of a NAS over the internet on my GX20 and it worked right away. There has to be something else blocking the request.
When you try to access the GUI over the internet, what is the error message you see on your browser?
markfit1
yes i agree and would assume it would have been a simple enough task and has proved otherwise 😞 if i pput in the external IP it just sits there and returns no error sadly just saying the site cannot be reached
Mark
Go News & Announcements
