Yamaha MusicCast Connection
Tschivi
Dear Community
I have had three Yamaha MusicCast devices connected to Apple Airport for years.
After switching to Meraki Go, I can no longer connect the devices to my network via WLAN. I can see in the log files that the devices connect for a few seconds and then disconnect again.
So far I have switched from NAT to Bridge and created a new SSID without special characters, but without success.
Unfortunately, the error messages on the Yamaha app and in the Meraki Go dashboard are very general, so I don't know what else I could do.
Does anyone have the same problem and could give me a hint?
Thank you for your support, Silvio
1 Reply 1
csamps
Hey Silvio, I was having the same prob and switched to Bridge mode. Also had to go with WPA2 under Wireless Access Control which got mine all working.
Good luck! Cheers, Chris
