Static setting
FORTISERV
Static setting
I think I'm in the right place. Still trying to setup the Meraki GX50. I'm just trying to do some basic setup. I need to change the static IP from 128.0 to 1.0. And I'd like to assign a static WAN. Very basic functions but not easy to find at all. I'm not to sure if I like this "cloud" base type stuff with this. Also, as I was getting one router setup it dropped the Internet connection 3 times. I put the old router back in place (RV134)and it hasn't gone down since. Lots of issues I guess. Does Cisco have a basic router anymore not cloud base for under 500? I was using the RV134W loved that router!
Thanks in advance, Craig
1 Reply 1
There is a specific community for Meraki GO.
https://community.meraki.com/t5/Meraki-Go-Community/ct-p/go
Take a look at the installation guide: https://documentation.meraki.com/Go/GX_Installation_Guide
