We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hello Community, do you know if the Meraki SFPs are compatible with the Meraki GO switches, or can we use the Cisco option?
Solved! Go to solution.
The Meraki SFPs are compatible with the Meraki Go switches.
Thanks,
Keithia
Meraki Go Support
