Novice help instruction with BT HUB
Solentmancub
I am trying to config a guest network and an Owners network ( B&B that is getting hacked)with BT HUB and Three BT discs. Two discs are meshed & one is a cottage via a TP link and ether net cable. I want a landing page and control over who can and can't stream as it kills my network. Any kind soul offer help and a solution ?
Solentmancub
No worries, I sent it back & now using a Draytek router. Much easier to get useful help with!
2 Replies 2
Anonymous
Not applicable
Hi there @Solentmancub -
Are you using any Meraki Go gear in this setup? Sounds like it's exclusively BT equipment?
If you are using BT equipment and no Meraki equipment, you might want to try the BT community - which I found here: https://community.bt.com/
Cheers!
Solentmancub
