Meraki Go having problems right now?
olavrb
Is Meraki Go experiencing problems atm? I've received 20+ emails the last hour or so of my hardware allegedly going offline. I'm not at location, so I don't know whether this is true. Also, I'm trying to disable email alerts (for now) in the app, but the app is so slow I can't do anything. Are you experiencing problems right now? Are all settings in app dependent on my hw being online, even my notification settings?
We only have 1x 48p PoE switch and 5 indoor APs atm, behind a Cisco RV345P router.
  • Are you experiencing problems right now?
  • Are all settings in app dependent on my hw being online, even my notification settings?
  • Is there a status page publically available for Meraki Go dependant services?
Moskeeto
Meraki Alumni (Retired)
Yesterday there was a large scale Level 3 outage in North America that intermittently impacted Meraki login globally. Due to the Level 3 outage, some users simply did not have Internet was down in their area.
If you continue to have issues with your Meraki Go environment, please submit a case and our team will be happy to assist.
Thanks,
Keithia
Meraki Go Support
olavrb
Thanks for the answer @Moskeeto, I thought it might be related to that outage.
Anyways, is there a status page for Meraki Go services available? Like:
Would be great with something similar to easily diagnose whether problems that occur is due to our environment (ISP, faulty equipment, cables) or external dependencies.
Moskeeto
Not at this time, but I would definitely encourage you to submit this as a feature request within the app by navigating to the settings tab and selecting "Give Feedback" under the Help section.
Thanks,
Keithia
Meraki Go Support
