Meraki Go Router internet port plugs into provider DSL connection
JC-Munyakazi
I would like to know if, is it possible to connect the Meraki Go router Firewall Plus directly to the ISP that uses a DSL connection without using the ISP modem.
Thanks in advance for your support.
Regards
JC
JC-Munyakazi
well, I just read the Meraki Go Router Topology documentation, unfortunately, the description describes to connect through the ISP Modem.
https://documentation.meraki.com/Go/Installation_and_Configuration/Meraki_Go_-_Recommended_Meraki_Go...
Thank you for being so supportive
regards
JC
1 Reply 1
JC-Munyakazi
regards
JC
