Inter-VLAN communication
CaptainMango
I try to configure my new Meraki Go setup. I've a GX20, GS110-8P and a GR10. The GX20 has the connection to the modem and a trunk connection on port 2 with the default VLAN1 and allowed VLANs "all". The GS110 has the default VLAN 1 with allowed VLANs "all" on port 1. the GR10 is connected via trunk ports on the GS110 on port 8 (VLAN 1, allowed VLANs "all").
I've a couple of VLANs, and I want that 2 of them can communicate between another:
  • VLAN20 with 192.168.20.0/24, GX has .1
  • VLAN30 with 192.168.0.0/24, GX has .1
There is a printer on VLAN30 with .79, connected to the GS110 on port 5. Port 5 is configured to be an access port with VLAN30.
There are a couple of PCs on VLAN20, all connected to GS110 ports which are configured as access ports with VLAN20.
Now, the problem is, that I cannot ping a device from VLAN30 to VLAN20. I tripple checked already that the "Secure this network" buttons for the networks are disabled, which they are.
I can't find any firewall or routing settings so I sadly can't really troubleshoot anything else.
What am I missing? Hope anyone can help!
1 Reply 1
CaptainMango
Hi, just a small update:
It seems that I can ping to other VLANs, however, I'm losing about 40-50% of the packets and the latency also seems very high:
("Zeitüberschreitung der Anforderung." = request time out)
>ping -t 192.168.0.79
Ping wird ausgeführt für 192.168.0.79 mit 32 Bytes Daten:
Antwort von 192.168.0.79: Bytes=32 Zeit=4ms TTL=63
Antwort von 192.168.0.79: Bytes=32 Zeit=3ms TTL=63
Antwort von 192.168.0.79: Bytes=32 Zeit=6ms TTL=63
Antwort von 192.168.0.79: Bytes=32 Zeit=7ms TTL=63
Antwort von 192.168.0.79: Bytes=32 Zeit=2ms TTL=63
Go News & Announcements
