How to block chrome remote desktop
soonoh
I introduced mx67 to the company.
Recently, I found that I control internal devices from outside using Chrome remote desktop.
I want to know how to prevent Chrome remote desktop from working in mx67.
I asked you a question because it was not simply blocked by url.
1 Reply 1
delfuego
This forum is for Meraki Go, not Meraki Enterprise. You can re-post you question there, or use the answers below. Best practice would be to deny the feature within application rather than to firewall it at the perimeter.
https://support.google.com/chrome/a/answer/2799701?hl=en
https://support.google.com/chrome/thread/97729787/how-do-you-disable-not-remove-chrome-remote-deskto...
