- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Error P
Hi All,
I can't login to either the APP or the web application as I get the error message "Error P".
Nothing works and I can't access therefore the routers., help@meraki-go.com does not answer any emails for weeks...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello @Som21
Are you able to log in to the local-satus page of your router?
You can connect to the page by entering the ip-address of your router or my.meraki.com if you're connected directly to the router.
This is just to see if your router is up an running correctly.
Did you try a different browser to access the web-application?
Another thing to try is the Solution on this post: Solved: "Invalid API Key" & "Network Error" - The Meraki Community
If you're still having problems reach out to support@meraki.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes the router luckily works, I have internet access.
Yes I did all the steps, unfortunately did not solve the issue. Thank you, I have already contacted help@meraki-go.com but no answer for weeks.
Opened a ticket at Meraki now, let's see...
also please note that support@meraki.com is not working anymore
BR
Soma
