Can I directly connect MerakiGo access point to the Modem
Harshad
I want to clean up by wiring closet ..and want to get rid of  switch, mainly used as POE for the AP
Can I directly connect Meraki Go AP to the modem  ?
1 Reply 1
Lee
You can directly connect the modem, but the type of modem will determine your setup options. If the modem is acting as a NAT router and issuing private IP addresses (listed below), the you can run your WiFi networks/SSIDs in bridge mode. This allows devices across the network to communicate with each other. If the modem is issuing public IP addresses, then your WiFi Networks/SSIDs will be configured in NAT mode, which will not allow devices on the network communicate with each other.
Private IP Ranges
10.0.0.0 to 10.255.255.255.
172.16.0.0 to 172.31.255.255.
192.168.0.0 to 192.168.255.255.
More Information
https://documentation.meraki.com/Go/Meraki_Go_-_When_Bridge_Mode_is_not_Available_(Auto_NAT)
