Sensor Data on the MS Summary Page
ShawnHu
Meraki Employee All-Star
The MT Environmental Table allows MS users to proactively identify issues in their environment by viewing MT sensor data on their MS Summary page.
  • Assigning an MT10, MT14, or MT15 to see the ambient temperature where the switch is installed.
  • Assigning an MT12 to check if there’s any water detected.
  • Assigning an MT40 to monitor input power metrics for switches.
To locate a list of MS switches with sensors associated, log into the demo platforms. Once logged in, navigate to Organization > Overview > Devices and search for 'Sensors' to identify the MS switches with the sensor data.
For how to set this up in your environment, please refer to the documentation.
8 Replies 8
Looking forward to seeing the switch data alongside the sensors, good stuff!
txhomer
Cool stuff.  Can a sensor only be assigned to 1 switch at a time?  I tried to assign a sensor to multiple switches but it seems like it only sticks with the last assigned.
Ryan_Miles
I noticed the same thing today. We’re looking into it to confirm whether that’s expected behavior or a bug.
ShawnHu
Thanks Ryan!
Ah, that sucks.  I'd gone through and assigned them all...  Hopefully it is a bug as it is essentially useless otherwise 🤬
Ryan_Miles
Me too. Will update the thread when I find out more.
Ryan_Miles
@cmr Looks like maybe this is fixed? I just assigned the same 4 Sensors to 2 Switches and it seems to have saved correctly. Can you give it a try on your side and confirm?
Excellent, thanks @Ryan_Miles it is fixed for me as well.  Now that's good service!
