ShawnHu,
Thanks for your information.
Before posting the question in the Meraki community I asked ChatGPT and the received the following question.
When I got your answer I felt suprised. Please the ChatGPT output including the attached .png file.
📌 Cisco Meraki MX250: Load Balancing Among Three WAN Links
The Cisco Meraki MX250 supports load balancing, but by default, it has only two dedicated WAN interfaces (WAN1 & WAN2). However, you can enable a third WAN interface by converting a LAN port into WAN3 and then distribute traffic among all three links.
🔹 How to Enable Load Balancing Across Three WAN Links
1️⃣ Enable a Third WAN Interface (WAN3)
- By default, MX250 has WAN1 & WAN2.
- You can convert a LAN port (e.g., LAN4) into WAN3 in the Meraki Dashboard.
📌 Steps to enable WAN3:
- Go to → Security & SD-WAN → Appliance Status
- Click → Uplink Configuration
- Change LAN4 (or another LAN port) to WAN3
- Save & Apply
Now, the MX250 has three WAN uplinks (WAN1, WAN2, WAN3).
