Black Belt - Meraki Deployment Stage 2 FY24 - Capture the Flag
shlomoi
I'm not sure this is the right forum but I'm doing a test of Black Belt - Meraki Deployment Stage 2 FY24 - Capture the Flag.
Did something make the second question.
I found the answer but I get an error message.
8 Replies 8
I don't know the answer - but the error says it has already been attempted.  So perhaps you only get one chance?
Contact the activity proctor, he will certainly help you. At least he helped me when I needed it.
ShawnHu
Meraki Employee All-Star
@alemabrahao is right. The demo environments provide platforms for various use cases and Capture The Flag is one of them. Your activity proctor will help you with the answer validation.
MartinLL
Try looking for the location of the device assosiated with Charles 😉
MLL
wiran
Just browsing
I also got the erros message.
Contact the activity proctor.
wiran
Just browsing
I have solved the problem
wiran
Just browsing
That is the hostname what you filled in. The flag answer should be: x/y examplex/exampley
