Traceroute from the MX LAN Interfaces
KentA
We have the ability to run pings from both the WAN and LAN IPs on the MX.  Unfortunately the traceroutes are limited to only the uplink interface.  The ability to run traces from the LAN IPs on the MX would be very useful
Xydocq
Hi @KentA
You might want to place your wish on the Meraki Forum Meraki Community
This Forum is for Meraki Go.
Cheers
2 Replies 2
Xydocq
Hi @KentA
Cheers
KentA
Whoops, thanks for pointing that out!
