After that, I'd recommend to look into pycharm and start doing the same things you've been doing in postman with Python. Here's a few of the steps to get going: Create a new projectGive it a namePyCharm will prepare everything for youGo to the project settings to add the Meraki libraryClick the little plusFind the Meraki module and install itAfter installing it it'll look like thisCreate a python fileTo get started with the code have a look at http://meraki.io/api. Every endpoint has an example which you can use as a template.Here's the simplest example that gets the id of all orgs you have access to. I just copied over the template and filled in my API key.
Hello @CSegovia! Welcome to the Meraki Community! It is a great community to be a part of and we are glad to have you here. I did exactly what @BrechtSchamp suggested and it is a great path to follow for learning the API.
CMNO, CCNA R+S
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_39b688234ee08e","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_39b688234ee08e_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_39b688234ee08e_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_39b688234ee08e_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_39b6881966f617","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
