Hi Meraki Community,
I was introduced to Meraki products in 2016 when a new coworker pointed them out as an up-and-coming company that Cisco had just purchased. I work at a City municipality and we have replaced our access layer and wifi at all the buildings. We have also implemented the easy to connect Meraki VPN teleworker appliances. The always online connectivity and ease of use makes it very easy to train interns and backup support. The only thing I have as an issue I still have not recieved Meraki swag. I even did a Thesis for my english class about Meraki as a vendor I appreciate!
3 REPLIES 3
Re: Hi Meraki Community,
Welcome! It's great to have you join us. Even I wish I had more Meraki swag, and I work for them! haha.
 Thank you so much 🙂
Welcome to the community. With the WFH contest maybe you'll be lucky! If not stick around, there are often opportunities to get swag.
