I joined this community while trying to find a solution to (what I think is) a Windows 10 update problem.... I'm hoping to find the magic fix. I'm a retired RF Engineer with 49 years in broadcast television. I'm somewhat computer literate and fairly trainable for the vast world IT knowledge in which I'm still unfamiliar.
I've used a Meraki VPN to connect to various networks I need to access for my work. It's always worked flawlessly - until this W-10 Pro 64b update tripped me up.
I do a lot of volunteer work at our community theater helping with the sound system, microphones and lights.
Hello and welcome to the community
You may want to check your Win 10 VPN settings - both for sign-in options (if you have username /password set) this will be under Settings>Network & Internet>VPN, as well as the Adapter settings in the network connections section.
Make sure that under the Security Tab that PAP is checked off and no other boxes.
I find that my win 10 changes those on me at will and I always check before connecting
Hope that helps 🙂
Welcome to the community!
(I don't actually know the cause or solution to your issue. I just wanted to welcome you.)
I want to thank everyone for their warm welcome!
