There is no official endorsement for that but physically Meraki classic MS switches just use QSFP+ for 40 G stacking on MS350 and below and probably is using QSFP28 for 100 G stacking.
You can also uplink switches to each other using the connectors on the back before they are even configured as a stack, so one has to assume they are regular ports and stacking is a little more software based in contrast to the custom connections a Cisco Catalyst switch would use in it's stackwise technology.
So I would lean towards the possibility that you could physical stack these switches using regular QSFP28 100G modules and fiber cable between them. However it's not supported in the documentation so someone will have to test it and see if it works and keeps working 😉
