Hello i´m playing with packet capture on my MR18 to try to see the traffic from a meraki NAT/DHCP network to my router. The problem i´m having is that i can not see the traffic from between my L3 switch to my router.
Setup is like this: Router > L3 Switch > Switch > MR18
did you select the wired interface?
cant you start the trace on the l3 switch or router?
You are using the SSID option where the SSID is configured to use NAT?
If so, the MR18 processes the DHCP traffic, not your router.
@ww should be right, you should be able to do a packet capture on the wired interface of the MR18. Note that because the traffic has already been NATed you'll only see traffic to and from the MR18 IP address.
