So two suggestions on this:
1. Have you tried doing a capture to a pcap file instead of to the display to see if it makes any difference? Are you seeing the traffic on the device connected to that mirror destination port?
2. I had a similar issue to this with one of our Meraki switches where I couldn't see the mirror traffic in a capture either because the ports weren't in the same asic (maybe wrong terminology there). I can't remember how many ports are grouped together in an asic (maybe 16) but basically, I had to make sure the source and destination ports were in the same asic for it to work properly.
