Device Removed from Network
Twitch
Hey everyone - is there any way to delete entries out of the client list in Network Wide --> Clients? The list has a lot of entries with Device Removed from Network, and I would like to remove those entries if possible. I don't even know where they came from, but I know where I would like them to go.
Also, I don't suppose there is any way to force the client list to re-populate/update itself, is there?
Thanks!
Twitch
3 REPLIES 3
Inderdeep
@Twitch : This may help, check out
https://documentation.meraki.com/SM/Device_Enrollment/Uninstalling_Systems_Manager_and_Removing_Mana...
Regards/Inder
www.thenetworkdna.com
Twitch
@Inderdeep- Thanks for the reply! I am going to assume that this only applies if we're running Systems Manager, correct? We don't have SM configured on our network, at least not that I am aware of. SM isn't an option in the left-hand menu list.
The only way I l know of is to change the client tracking setting (and then you can change it back again) - but you can't do this for all network setups.
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client-Tracking_Options
The most common reason I've seen for "Device removed from network" is when a client is manually added to the dashboard (such as pre-provisioning a new client with group policy) and then it never connects.
It might also be the Dashboard has not seen the client in a while.
