Hi All,
My Network isn't allowing Home Sharing on the Apple TV, I removed the CISCO Network and replaced with a simple Vodafone Router and it works fine.
Please any advice would be great.
Thanks.
C.
Solved! Go to solution.
I have Single never used a VLAN,
I put the WiFi into Bridge Mode as advised my Meraki Support and it worked first Time.
Thanks for your help!
C.
Wired or wireless? Did you have the SSID in NAT mode?
C.
C.
Have you turned on rendezvous support?
