Airplay over different VLANs/Subnets
Holli69
we have some schools with the following situation:
- MX -> MS Layer 3 -> MS Layer 2 -> some MR46
The Layer 3 Switch is responsible for Routing, MX has only VPN and Firewall functions.
We have the following VLANs:
VLAN 10: Digital Whiteboards/TVs with Airplay
VLAN 20: iPads for teacher
VLAN 30: iPads for students
At the moment, it's not possible to share the screen(e.g. Youtube Videos) from iPads (VLAN 20 and VLAN 30) to VLAN 10 TV's via Airplay
My question is, if it's better to solve the problem via forwarding the Bonjour protocol on MR (Access Controll) or must I solve this with Multicast Group (VLAN 10,VLAN 20,VLAN 30 in one Multicast Group) ?
BtW: Is Airplay sending broadcast messages to all clients in the same VLAN/Subnet ?
BrandonS
I think you can just enable it on the MR: https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Bonjour_Forwarding
Airplay should broadcast within it's own subnet/VLAN, yes.
Holli69
I tested Bonjour Forwarding Configure->Access Control->Bonjour Forwarding, but it didn't solve my problem. On my iPad, I can't see the broadcasted Airplay display device for screen-sharing.
For my understanding, the Service VLAN is the VLAN where Airplay is Broadcasted, in my case VLAN 10 Digital Whiteboards/TVs with Airplay
If the display device is in the same Subnet, it works perfectly.
Do you know another solution, why it doesn't work in different Subnets/VLANs?
BrandonS
In order to for Bonjour forwarding to work, the Bonjour client and server must have a routable path on layer 3 between them (i.e. they must be able to ping each other).
Yes, ping is possible in both directions and non of the VLANs are isolated
