A new candidate wireless firmware is now available on Tue, 18 Feb 2025
FirmwareBot
A new candidate wireless firmware version is available. Firmware MR 31.1.6 was just released on 2025-02-18 and has been in this firmware category since 2025-02-18.
2 Comments
Wireless firmware versions MR 31.1.6 changelog
Important note
Bug fixes
  • General stability and performance improvements
  • MR56 ethernet port flaps occur when connected to C9300-48UN(V04) at 5Gbps speeds
  • MR57 ethernet port flaps occur when connected to MS355 at 5Gbps speeds
  • MR46 not responding to Probe Requests from clients
  • Channel & power not configurable via LSP on CW9163E APs
  • Wildcard NAS-IPv6-Address AVP sent on config change (Wi-Fi 6, Wi-Fi 6E APs)
  • NAS-IP-Address discarded (Wi-Fi 6, Wi-Fi 6E APs)
  • RADSec authentication failures (Wi-Fi 6, Wi-Fi 6E APs)
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)
  • DHCP offer is not forwarded if broadcast flag is set (Wi-Fi 7 APs)
  • mDNS traffic blocked (Wi-Fi 7 APs)
  • SSIDs broadcast on 6Ghz despite being disabled when using WPA3 transition mode (Wi-Fi 7 APs)
As per the main forum post, originally the below was listed as a known issue, so may need validating:
