A new candidate wireless firmware version is available. Firmware MR 29.6 was just released on 2023-04-28 and has been in this firmware category since 2023-04-30.
While Meraki APs have traditionally relied on UDP port 7351 for cloud communication, and TCP ports 80 and 443 for backup communications, with MR 28+ we are beginning the transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the "Help" > "Firewall Info" page is allowed through any firewalls or security devices that are deployed upstream of your Meraki APs. These requirements have been updated in November of 2022, so it is important that you review them. (Wi-Fi 6 and Wi-Fi 6E APs)
Legacy product notice
When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
Bug fixes
General stability and performance improvements
Ethernet PHY optimizations (MR30H)
AP may stop sending MQTT updates
AP may send client balancing updates when disabled
AP may stop beaconing 5GHz BSSID after multiple DFS events (Wi-Fi 6 and Wi-Fi 6E APs)
AP may continue to send traffic to a client after it has roamed to a new AP
AP may reply to every LLDP packet from a PSE
AP may not broadcast setup SSIDs on factory firmware (Wi-Fi 6 and Wi-Fi 6E APs)
AP may reboot when the “Client Balancing” feature is enabled (Wi-Fi 6 and Wi-Fi 6E APs)
Numerous fixes to address MT connectivity at scale (Wi-Fi 6 and Wi-Fi 6E APs)
Known issues
Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3cb60f0be9cb41","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3cb60f0be9cb41_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3cb60f0be9cb41_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3cb60f0be9cb41_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3cb60f04b4a36c","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
