A new candidate switch firmware is now available on Wed, 17 Sep 2025
FirmwareBot
A new candidate switch firmware version is available. Firmware MS 18.1.2 was just released on 2025-09-17 and has been in this firmware category since 2025-09-17.
1 Comment
Switch firmware versions MS 18.1.2 changelog
New feature highlights
  • Group Policy ACL on MS130 & MS150
  • Maximum MAC support in MAC Allowlists
  • 802.1x limited access mode with pre-auth GPACL
  • Local Status Page connectivity diagnostics enhancements
  • Layer 2 multicast live tool
  • Traffic Mirroring: RSPAN & VLAN Based SPAN
Fixed issues
  • Fixed a bug in Voice VLAN bypass, which caused Voice clients to get authenticated when re-authentication interval was configured
  • Fixed an issue with MAB authorization that incorrectly placed clients in Critical Auth VLAN when suspend port bounce was enabled
  • Resolved an issue that sometimes prevented SmartPort Automation rules using LLDP from correctly functioning with PoE+ clients on mGig ports
  • Resolved a bug that sometimes caused clients to get stuck in an authentication loop after failing to pass an initial RADIUS authentication
General known issues
  • MS130 and MS150 switches may incorrectly remove or update SGT tags when no policy or VLAN mapping is defined. Until a firmware fix is available, correct SGT tags can be preserved by defining a policy for the SGT group in Adaptive Policies, and binding the SGT group to a VLAN using VLAN profiles.
  • Clients authenticating via 802.1X with an access policy using hybrid authentication may not correctly log their RADIUS sessions
  • In rare circumstances switches may experience uplink instability when IPv6 link-local addresses are enabled. If this issue is encountered it can be resolved by enabling IPv6 RA Guard to block ICMPv6 neighbor discovery messages.
  • LACP links may take an extended time to come back up when the Active Member of a stack reboots
  • Some switches may encounter an error, "incompatible configuration for attributes: allowed_vlans" when attempting to aggregate ports regardless of allowed VLANs configured in Dashboard
Ms120 known issues
  • Switches may fail to provide PoE power to legacy access points (always present)
  • Cable tests may report incorrect cable lengths
Ms225 known issues
  • MS225 switches may infrequently stop forwarding client traffic until the switch is rebooted
Ms35x known issues
  • Switches may experience an unexpected reboot (present since MS 15)
Ms355 known issues
  • Switches in stack configuration may experience some ports failing to reconnect after a firmware upgrade
Ms410 known issues
  • Some MS410 switches may encounter alerts for fan failures that will eventually self-resolve
Ms425 known issues
  • In rare circumstances MS425 switches may encounter a software crash that results in a reboot
  • Switches in stack configurations may experience high CPU utilization in multicast scenarios that may result in network instability
