A new candidate cellularGateway firmware version is available. Firmware MG 3.0 was just released on 2023-03-10 and has been in this firmware category since 2023-03-14.
This is 3.00 moving from beta to stable release candidate, but bizarrely the release notes are now as below:
Other
MG 3.0:
First beta image! 🎉
Cellular WAN Connectivity
NAT and Passthrough modes supported
IPv6 Support (Firmware only)
Dual SIM Support - SIM slot selection via dashboard/LSP
Auto SIM failover - if SIM1 is not present, auto switch to SIM2
ZTP via auto APN detection and multi-APN retry
Custom APN setting via dashboard/LSP
Safemode for troubleshooting
Known Issues
DHCP section is not disabled in passthrough mode
Licensing is not enforced properly on Dashboard. Device shows up as a "wireless AP" on the licensing page
Enabling/disabling SIM PIN/PUK currently unavailable
Limitation
If SIM1 is configured as Primary, Dashboard will not show the details of SIM2 until SIM2 is made active. If SIM2 is configured as Primary, Dashboard will likely have the details of SIM1
Changing carrier provided MTU is not available. ECO is available to change MTU only in passthrough mode
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b2cc008742210","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b2cc008742210_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b2cc008742210_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_3b2cc008742210_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_3b2cbffc6a61a3","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
