A new beta switch firmware is now available on Tue, 19 Aug 2025
FirmwareBot
A new beta switch firmware version is available. Firmware MS 18.1.1 was just released on 2025-08-19 and has been in this firmware category since 2025-08-19.
1 Comment
Switch firmware versions MS 18.1.1 changelog
New feature highlights
  • Group Policy ACL on MS130 & MS150
  • Maximum MAC support in MAC Allowlists
  • Multi-auth support for Guest, Critical, and failed VLANs with 802.1x limited access mode
  • Local Status Page connectivity diagnostics enhancements
  • Layer 2 multicast live tool
  • Traffic Mirroring: RSPAN & VLAN Based SPAN
General fixed issues
  • Fixed a bug that caused an incorrect SNMP response of “0” when polling switches for ifInDiscards
  • Resolved an issue that caused frequent notifications about new DHCP servers that have mismatched VLANs/subnets
  • Fixed a bug that prevented switches from correctly flushing MAC addresses matched to a switch port after disabling or disconnecting the port
  • Resolved an issue that prevented some clients from accessing the Local Status Page via 1.1.1.100 and and switch.meraki.com while the network was configured for with Track-by-IP or Cloud Track
  • Resolved a bug that prevented MS250 and MS350 switches from correctly removing MAC addresses learned via AGGR when LAG ports were disabled
Ms130 fixed issues
  • Fixed a bug that caused some DNS response packets to be lost when DNS inspection was enabled
Ms150 fixed issues
  • Resolved an issue that caused degraded uplink speeds when an MS150 was connected to an MX device using an mgig port
  • Fixed a bug that caused occasional software crashes and reboots on MS150s in stack configurations
  • Fixed a bug that, in rare cases, could cause member switches in MS150 stacks with cross-stack LAG links to have incorrect MAC-to-port mappings
Ms225 fixed issues
  • Fixed a bug that occasionally caused software crashes and switch reboots when more than 8 hybrid auth clients were connected to the same port
Ms250 fixed issues
  • Resolved an issue that caused ports to fail to connect after performing a cable test
  • Fixed a bug that sometimes caused switches enter a 'port not forwarding' state, where client devices were placed on the guest VLAN, and prevented the switch from sending RADIUS requests until rebooted
Ms35x fixed issues
  • Resolved an issue that caused switchport LEDs to show an Amber light while the UI showed that the port is negotiating while using 2.5Gbps mgig ports
Ms425 fixed issues
  • Fixed a bug that sometimes caused core stack members to encounter MRMP failures, which resulted in the stack or the network going offline
  • Resolved an issue that sometimes caused up to 5 minutes of downtime after powering off the active switch in a MS425 stack
General known issues
  • Clients authenticating via 802.1X with an access policy using hybrid authentication may not correctly log their RADIUS sessions
  • Clients that fail to pass RADIUS authentication and are connected to ports using access policies may get stuck in an authentication loop, possibly resulting in a switch reboot
  • In rare circumstances switches may experience uplink instability when IPv6 link-local addresses are enabled. If this issue is encountered it can be resolved by enabling IPv6 RA Guard to block ICMPv6 neighbor discovery messages.
  • LACP links may take an extended time to come back up when the Active Member of a stack reboots
  • Some switches may encounter an error, "incompatible configuration for attributes: allowed_vlans" when attempting to aggregate ports regardless of allowed VLANs configured in Dashboard
Ms120 known issues
  • Switches may fail to provide PoE power to legacy access points (always present)
  • Cable tests may report incorrect cable lengths
Ms225 known issues
  • MS225 switches may infrequently stop forwarding client traffic until the switch is rebooted
Ms35x known issues
  • Switches may experience an unexpected reboot (present since MS 15)
Ms355 known issues
  • Switches in stack configuration may experience some ports failing to reconnect after a firmware upgrade
Ms410 known issues
  • Some MS410 switches may encounter alerts for fan failures that will eventually self-resolve
Ms425 known issues
  • In rare circumstances MS425 switches may encounter a software crash that results in a reboot
  • Switches in stack configurations may experience high CPU utilization in multicast scenarios that may result in network instability
